Well, I'm trying to solve the fuel issue. The bus is not getting gas. Spray a little starter fluid down the carb and she jumps to life. The points, coil, valve adjustment and timing all look good. She has spark.
I crawled underneath this morining and messed with the fuel tap lever. You can see in the pics below there are two settings. For lack of better terms, I call them "up" and "down". In either setting, I can't get a flow through the tap to fuel pump. I have an in-line clear filter under the bus between the tap and engine tin, but it is bone dry. So the tap isn't letting fuel run and the pump isn't gettting any fuel.
Yes, I put the screen sleeve and the little red rubber gasket in the tank before screwing the tap in. There is at least a gallon of fuel in the tank, but I can't figure why it wont run into the hose in at least one of the two tap settings (reserve). I thnk Kirk can verify we blew through the copper (brass) tubes before install.
Is there more than one way to put those taps back together?
While I figure the fuel issue out, I got the "cave man" wiper system back together. I think I'll need some guidance on how to adjust them to the "parking" setting. These early buses have a real "stone age" wiper system. It's basically two wire arms that snap onto the wiper shafts and then hook on the back of motor. A real pain to put together, not becase they are complicated, becase they are so darn hard to reach! Here are some pics for future reference.
Here is the fuel tap in the "up" positon
Here it is in the "down" position
Here is the "dry" in line filter
Here's the Barney Rubble 6V wiper motor
Here are the linkage points under the dash
I got the last pop out window in and went with a non-correct big spoon latch for mazimum air. I have the original for the stock nazis down the road
