Page 1 of 13
Kirk's........1960 Double Cab
Posted: Fri Dec 19, 2008 9:11 am
Well, I started to move again on the DC.
The plan right now (a very loose one) is to replace some sheet metal and make it all one color again.
Along the way I would like to install some original safari windows.
What I need to do this winter:
1. cargo door lower
2. both front doors
3. both doglegs
4. right & left front floor sections
5. front nose (very bad inside and out)
6. safari windows
7. paint or primer Dove blue again
Re: CaptKirk........1960 Double Cab
Posted: Fri Dec 19, 2008 12:35 pm
Can't wait to see all the detailed pictures. This will likely be the 'great project of 2009'!
Posted: Fri Dec 19, 2008 8:18 pm
by Josh
Are those cut up telephone poles in the back of you DC?
Posted: Fri Dec 19, 2008 10:16 pm
Yes, they make for great kindling/starter wood for the fireplace at home.
Posted: Sat Dec 20, 2008 7:57 am
by Randy
Looks like it is a great project. Is that the same truck you have had at RRR? Pretty sold to begin with.
Posted: Sat Dec 20, 2008 8:11 am
by 21window
Is that rubber bungee supposed to be holding the logs in case they fall?
Posted: Sat Dec 20, 2008 7:11 pm
21window wrote:Is that rubber bungee supposed to be holding the logs in case they fall?
Yes. Kirk is big on OSHA standards.
Just kiddding. Kirk really is big on safety. He wears eye and ear protection even when I'm talking to him.
Posted: Sun Dec 28, 2008 9:37 pm
Check out the pile of high $$ Gerson metal panels, they do look to be pretty good. I'll let you know how well they fit later.....
This is the guy making them
http://www.klassicfab.com/marcos.htm
The only one stocking in the USA (not back ordered) is
http://www.bustoration.com/Metal-Repair ... _c_11.html
Started with the cargo door:
Ended up with this:
Posted: Mon Dec 29, 2008 7:58 am
Good stuff Kirk and very interesting. Looks like the panel fit very well. Keep us updated this is good learning material.
Posted: Mon Dec 29, 2008 10:47 am
by vw7266
nice werk kirk...i put a gerson rocker and crossmember and outriggers on my single they all fit pretty nicely. your work looks great...I love that DBL
