Drivers side body panels needed for 1969 Type II Campmobile
Looking to restore a 1969 Type II bus and need drivers side body panels. The two behind the drivers side door. Any help sourcing these would be greatly appreciated. Hoping to get it done before my wife's birthday at the end of October. Thanks!
Re: Drivers side body panels needed for 1969 Type II Campmobile
Hi - did you try:
Mill Supply ?
CIP1 ?
That guy (Mark) doing the split might have something too and he is in sandusky. ?
You might just have to take flat and bend it to fit ?
I have bought the long side wall for split - the tall one for my 67 from CIP1, along with cargo floors, and also the short long wall panel too. Hey, I have several splits, one of them will use it. - Meaning, maybe you can use a split bus panel and modify it ??
After you get the steel, please Consider 3M panel or aftermarket panel bond to glue that in place. Long panels like this like to warp when you are welding, don't have that problem with glue ! I glued my 78 slider door and that panel came from Mill Supply.
Good luck !
Mill Supply ?
CIP1 ?
Good luck !
