2018 Tune Up Day - May 12th
Re: 2018 Tune Up Day - May 12th
Post by Dual Port » Thu Apr 12, 2018 10:02 am
If you are not familiar with the location of my shop, it's in the south part of Berea right near the turnpike and turnpike building. Spudnuts Donuts is about 200 yards north of me (Prospect and Sprague). My address is 686 Prospect, Berea, 44017, which is also State Route 237. It's right near the turnpike crossover on 237, the turnpike building, about 1.5 miles south of Berea downtown, and 2.5 miles north of Rt 82 Strongsville.
BUT- DON'T go to the front building which is marked 686, they won't know what you're there for.
Turn down Greenfield Court, drive 100 yards, and turn right through the gate. If you're using GPS a better address might be 16 Greenfield Ct, Berea, OH 44017. You won't miss my building.
Rain or shine, we'll see you there Saturday May 12th! There's no specific time, I'll roll in about 8:30 or so, most people will probably drift in about 10ish. There will be hot dogs and maybe other stuff, and some people will bring donuts. Spudnuts is walking distance if you forget. :D
Flamingo
Post by Flamingo » Thu Apr 12, 2018 12:49 pm
wwebner wrote:
Thu Apr 12, 2018 7:45 am
Flamingo wrote:
Wed Apr 11, 2018 7:41 pm
Can do. Mat be a most of day job.
Thanks alot! I'm really looking forward to this.😁
Post by Ken » Fri Apr 13, 2018 9:05 am
I would like to do a leak down test and compression check on a 1600 SP motor.
Post by wwebner » Mon Apr 16, 2018 8:38 am
If you need tune up parts, plugs,wires,points cond,cap. call Mick at Euclid Foreign 440 465 1985. try to have your distributor #,
Also, I have a supply of shift bushings for most buses,if you have a sloppy shifter,this is a good opportunity to fix it.
Frankinbus
Post by Frankinbus » Mon May 07, 2018 7:49 pm
my drivers door bottom hinge is tearing off at the rivets. my bentley manual says to weld the rivets on the inside and put a reinforcement plate on , they even have a part number for the plate. also the piping at the top of the door card came unstapled, does someone have a small stapler for that. thanks
65 11 window bus
2012 turbo beetle
1964 berry mini t buggy
Post by wwebner » Mon May 07, 2018 9:14 pm
I have the stapler,will bring.
Post by Karl Kombi » Tue May 08, 2018 8:50 pm
I know there was some talk of moving Tune Up Day back due to Bruce's schedule. Is it still Saturday morning?
Thanks! :|
Post by Marla » Wed May 09, 2018 5:05 am
Yes. No changes. We are still on for Sat.
I plan on picking up some donuts. The hot dog machine will be rolling. Come on out and chat even if you aren’t planning on working on a project.
Flamingo
Post by Flamingo » Thu May 10, 2018 11:37 pm
I will be bringing a couple of bags of McDonald's breakfast foods and an assload of cheap beer. 😁
Post by Six Volt » Fri May 11, 2018 6:44 pm
The Lurchmobile needs bushings. Can you bring a set for a '78 bay? I'll cover you when you get there.
It's me, Sean
1957 Beetle Oval Sedan 36 Horse 6 volt
1959 Panel 40 Horse 6 volt
1969 Standard 1600 and 6 volts too many.
