Many thanks to Bruce and Pat for extending their hospitality to the group for the annual tune up day. I arrived late, so I have no idea of the early morning shenanigans. As if if there were any!
One of the best things about Tune up Day, besides actually doing something to your rig, is reconnecting with fellow VW enthusiasts that you haven't seen over the winter. All of us are older and some of us (me) are even grayer and fatter.
So after a busy morning, I fired up the Lurchmobile and headed out to Bruce's shop. In less than a mile I encountered this alien craft.
WTF? When did folks from the Jersey shore or Floriduh move to West Park?
Anyway, upon arrival I found the usual suspects engaged in plenty of conversation and only a little work!
Spent some time talking with Will and Keith. Will is in the middle of a major project. He needs to start a thread on that!
It's always great when Aaron shows up. Even when wearing a Monkey Nut shirt instead of rockin' Widefive gear. We'll work on his marketing skills.
Matt Keith had a day pass. Great to see him! There was a lot of activity around Marla's bus. My takeaway? A centermount antenna can reek havoc on your windshield wipers!
She got it sorted out.
Chuck took care of Phylis's headlight problem.
As much as I want to separate from the Lurchmobile, I got talked into fixing a couple things I've complained about. Two big ones were the "slop" in the shifter and the headlight that's "out", but not dead.
Thanks to Bruce, Chuck and Bill both are fixed. Bill provided me with a front bushing to "cure the slop" and then said why not do it? Bruce has a lift and you have the part, so let's go!
Bruce stepped in and with some pointers from Chuck on "baynomics" he had the shifter shifting in no time. (The double entendre references in this thread may reach an all time high!
First take out the shifter.
The pedal pan underneath has to come off so you have access.
My bushing was missing so the rod pierced the hole in an unregulated manner.
The screw on the coupler has to be removed to release the two parts so the rod can be removed.
Bruce asked if we have any leaking gas. Why no, what could go wrong?
In the end Bruce cleaned up the shifter plate and Dan (Lurch) adjusted it after a short ride.
Bruce then fixed both headlights by chasing down the bad grounds at the fuse box. Memo to all: "Clean your grounds and electrical connections." Disconnect the battery!
To everyone who came that I failed to mention, it was great to see each and everyone of you. LEAKOIL is a great group because of each and every one of you! See you at the next third Thursday or at the MetroParks cruise.
[attachment=3]IMG_2228.jpg[/attachmen]
