The UNofficial bus (stuff) for sale on CList (& others) II 2017
Re: The UNofficial bus (stuff) for sale on CList (& others) II 2019
Post by Dual Port » Thu Oct 10, 2019 1:32 pm
Re: The UNofficial bus (stuff) for sale on CList (& others) II 2017
Post by blue71 » Thu Oct 24, 2019 5:50 pm
Not mine
THINGE
Post by THINGE » Thu Nov 14, 2019 10:58 pm
1966 VW 13 Window Deluxe Bus
1974 VW Thing (2)
1977 VW Westfalia
Post by Dual Port » Fri Nov 15, 2019 10:04 am
John Watjen was interested in this bus last week so we went out to look at it, the seller's description is accurate- typical Ohio rust in the door bottoms and etc. Some surface rust in the windshield frame but not rotted bad, if you sandblasted these spots they would pinhole. Frame and important stuff underneath is good, but expect normal problems like brake lines etc as they're all OE. Not original color, it was brown/tan IIRC. CV boots are torn. Fuel gauge inop. He has an extra slider that he's including with the sale. It runs and drives well but has an exhaust leak at one port so it's slightly noisy. Sunroof might work with difficulty but leaks so the interior is quite moldy. 40k original is a stretch but not impossible. Overall not bad if it's what you're looking for, John already has too many Vanagons so he passed on it.
Post by wwebner » Fri Nov 15, 2019 11:01 am
79, one year only heat exchangers. Although,not a big prob,as 72-74 can be easily modified to work on one year only (for bay) cyl heads, same as air cooled Vanagon square port. BUT, it is a bay sunroof. Too bad about the color change.
Post by Six Volt » Fri Nov 15, 2019 11:24 am
Out of curiosity, are the sunroofs from that era a PIA? I'm assuming all the parts are available if needed?
It's me, Sean
1957 Beetle Oval Sedan 36 Horse 6 volt
1959 Panel 40 Horse 6 volt
1969 Standard 1600 and 6 volts too many.
Post by toolbox » Fri Nov 15, 2019 1:32 pm
A lot of the parts are only available used, the drain tubes clog and rot inside the body causing all kinds of issues if not kept clean.
THINGE
Post by THINGE » Sat Nov 16, 2019 8:00 pm
1974 VW Thing (2)
1977 VW Westfalia
Post by Dual Port » Sun Dec 29, 2019 3:15 pm
