Re: Bill's T4 engine build
Posted: Thu Dec 19, 2019 5:06 pm
Now we are going to hang the rods for some measurements. First, wipe the bearings,rod big end and rod journal clean.
although the bearings come sealed in plastic, doesn't mean they are clean. We are installing the rods "dry" for this procedure. Install the bearings in the rod end. Now we are going to measure the oil clearance between rod and rod journal. This is critical. tight enough to maintain oil pressure, but loose enough for the rod to move on the journal. Vw specifies .0008 to .0027 with a sloppy .006 wear limit. Plastigage, which is a precicsion wax thread. a smaal piece is laid across the rod journal.
NOTE: since the machine shop had the rods,and bearings, and also the crank shaft,flywheel and pressure plate in order to balance that rotating assembly, I had them take these measurements. But, I am going to mock this up to show the procedure. Now CAREFULLY install the rod and torque to spec. This is tricky as you don't want to move the rod and smear the plastigage. Then, CAREFULLY, remove the rod. Also tricky so as not to smear the plastigage.
Then use the package to measure. This one (shitty picture) was between .0015 and .002, which is good. as a comparison, a sheet of printer paper is .003. Ideally, you would do this to all 4 rods. Now, after cleaning the wax off the rod journal and bearing, we are going to hang all the rods again to measure side clearance. This is another mock up as I can't find or did not take pics.VW specs .004 to .016 with a wear limit of .027
I had 3 that measured .006 just like the mock up. I had 1 that measured .017.which is within spec. But, We will deal with that next.
