Page 21 of 27
Re: Rick's 1969 DOUBLE CAB
Posted: Wed Sep 29, 2010 3:38 pm
vwrick69 wrote: I have about had it with this thing!!!!!!!!!
I will take that horrible thing off your hands.
Posted: Wed Sep 29, 2010 4:35 pm
by Ron
Are you sure steering column and box are working properly?
Posted: Wed Sep 29, 2010 5:43 pm
Posted: Wed Sep 29, 2010 6:08 pm
by Ron
OOOPs this thread IS getting too long for me I guess.
Posted: Wed Sep 29, 2010 8:51 pm
I'm not sure I've read it all either Ron. But I'm still not understanding how tight ball joints = fishtailing all over the road and can't go more than 35mph? Help me understand just in case I purchase a bay window bus.....
Posted: Wed Sep 29, 2010 8:58 pm
Posted: Wed Sep 29, 2010 9:22 pm
Rick, is all the suspension stock stuff or did the PO do something to mess with the geometry?
Posted: Wed Sep 29, 2010 10:03 pm
by Josh
This is what you need Rick
Posted: Thu Sep 30, 2010 1:44 am
by vwrick69
The balljoints are binding, when you turn it to the left a little to correct, it doesn't return to center, it doesn't return at all. Then you have to turn to the right and it stays there. Then it is back and forth left then sticks, right and it sticks, back and forth then you are fishtailing all over. The balljoints they used were VW/AUDI. The tierods are fine, not loose not too tight. The drag link is good also. The only issue, other than balljoints, the center pivot has a little movement up. The suspension is all stock as far as I know.
Posted: Thu Sep 30, 2010 1:46 am
by vwrick69
vwrick69 wrote:NEW BRAKE LINES AND INSTALLED REGULATOR VALVE
Looks stock
