Page 5 of 22
Posted: Thu Dec 19, 2013 9:32 pm
Way to go Rick. Problem is you won't be able to join the off road outing in a slammed bus :lol:
Posted: Sat Dec 21, 2013 8:27 pm
by Busjunky
I wish my project had some savable og paint under it. Pat had this late bay i worked on that had 3 layers of paint and he started to sand it off. It turned out to be a collage of paint and it looked pretty cool. Nothing looks cooler then a lowered split all patina'd out with some dual webers in that beast. In my humble opinion that is.
Posted: Sat Dec 21, 2013 9:36 pm
Still having some trouble with my blue-white paint... Probably have to get some rattle can paint burned through a couple spots :/
Posted: Sun Dec 22, 2013 11:48 am
by Busjunky
Have you tired any chemical paint remover products? Also, Smetzer Paint in Avery, Ohio makes one hell of touch up rattle can paint. Its about $20 a can and has the hardener and reducer mixed in. Works awesome for the little areas that you burned thru. They have all the old vintage vw paint codes
Posted: Sun Dec 22, 2013 3:45 pm
" Smetzer Paint in Avery, Ohio makes one hell of touch up rattle can paint. Its about $20 a can and has the hardener and reducer mixed in. Works awesome for the little areas that you burned thru. They have all the old vintage vw paint codes"
good info :)
Posted: Sun Dec 22, 2013 3:58 pm
Busjunky wrote:Have you tired any chemical paint remover products? Also, Smetzer Paint in Avery, Ohio makes one hell of touch up rattle can paint. Its about $20 a can and has the hardener and reducer mixed in. Works awesome for the little areas that you burned thru. They have all the old vintage vw paint codes
Thanks! I will definitely look them up! Ill need some! And for the removers, the paint over my white has been tough. Easy-off has been super slow. Ive been diluting stronger stuff with some success. Just taking it slow.
Posted: Thu Dec 26, 2013 9:01 pm
by Busjunky
When I used easy-off i found that it worked extremely well when the metal was warmed up and in the sun. I got one entire side stripped in just a hour or two. The next day i came back in the morning. My bus was in the shade still and the easy-off was nearly useless. I waited till the afternoon and tried it when it had warmed up. It worked like a champ again. That was in my experience. Results may vary, but try cranking up heat overnight and give it a go in the morning. Hopefully your indoors. Also, that paint Smetzers makes is Nason brand and its mixed right there in front of you. Its a PPG brand. Ive had alot of great results from it. Its awesome for patina matching.
Posted: Fri Dec 27, 2013 9:52 am
In addition, I noticed a huge difference between spray can EASY-OFF and spray bottle EASY-OFF. The spray can stuff was much better. This is old info from years back but it might still apply.
Posted: Fri Dec 27, 2013 1:33 pm
Dual Port wrote:In addition, I noticed a huge difference between spray can EASY-OFF and spray bottle EASY-OFF. The spray can stuff was much better. This is old info from years back but it might still apply.
Ok. I have both but I will go with the aerosol can. Thanks.
Posted: Sun Dec 29, 2013 1:02 pm
For the paint,instead of paying $20 a can. You could use this,available at most automotive paint supply stores. About $5. replacement aerosol is about $3. You can then have your paint mixed by the quart. Something any automotive paint supply shop can do.
