Page 7 of 11
Posted: Sun Mar 01, 2009 9:35 am
Either way is OK.
Posted: Sun Mar 01, 2009 1:50 pm
by Ron
Sounds like you have the "spark" side of combustion right. Now look at "fuel" side. Would be my guess. Make sure it is getting fuel.
Posted: Sun Mar 01, 2009 5:39 pm
by framingsilly
cool Ron that sounds lodgical,I'll do that next,Just getting driven crazy over this < Ive been trying to start this motor for a week and nothing. The two major things Ive changed are the fuel pump wiring(double relay from German Supply).The fuel pump makes noise when I try to crank it over so I assume it's working.And well I guess its just one thing.Maybe I'll check over all the wiring.I need to check if I have spark also , didn't do that either.So I havent tried everything yet.
Posted: Sun Mar 01, 2009 5:40 pm
by framingsilly
I think i'm going to wire the fuel pump to the coil to see if it's my double relay wiring????????????????????
Posted: Sun Mar 01, 2009 6:04 pm
by Ron
I would try starter fluid. If it fires up and stalls in a second you know it is not getting fuel. I have never heard of starter fluid being a problem but I am no expert.
Posted: Sun Mar 01, 2009 8:43 pm
It's only a problem if you use it for extended periods. It tends to dry the oil from the cylinder walls and could cause scoring. Most of the newer brands have a lubricant added. That's what I would use - read the label.
Posted: Mon Mar 02, 2009 8:07 am
by framingsilly
Okeydoke I'll try starter fluid.To check for spark do I pull the plug wire off #1 plug , turn the key to the first position and turn the motor with a wrench till the rotor hits were #1 shoud fire , and hold it close to some metal? Thanks for all the advice,I was going a little nuts yesterday but calmed down.
Posted: Mon Mar 02, 2009 2:47 pm
by framingsilly
OK no spark! I was using jumper cables so I pulled the battery to charge.When I use the static timing light on the coil it works so I would amagine theres power going to the coil(from the alternator/starter).I tried another coil just to check.I'm reading the idiot book now,but if anyone knows what to look for that would be great.peace!
Posted: Mon Mar 02, 2009 4:21 pm
by framingsilly
Maybe ad condenser?
by framingsilly
bad condenser
