Page 9 of 15
Re: 1961 Microbus
Posted: Sat Nov 09, 2013 6:23 pm
5 hours today, new total 152.
finally got some metal in, so hopefully I can get the rear section done before the snow sets in...
I plan on getting all the metal I need for the cab area over the winter, so when spring comes I can hit it hard.
anyway, todays progress
I started with the left rear corner
as you can see it was pretty chewed, remarkably the tray was in decent enough shape that I just left it...
couldn't say the same for the bottom of the wheel well though, so I cut the cancer out
and made a new piece and welded that in
With that back in, it was time to tack up the panel. Obi Wan Kirk Nobi gave me some sagely advice about installing the Gerson corners. He said "if there is one thing I cannot stress enough its....." I forget what he said, so I decided to wing it
for those astute viewers, you will notice I didn't spot weld the battery tray. I said "screw it"
the panel fit really well with the exception of being about 1/8" or so short
I will get the long reach chisel out tomorrow and see if I can massage that a little tighter from inside the engine bay.
since I like to commune with nature in my shop (its outside on my driveway), I am kinda bound by nature. It was windy today, so I had to use flux core to set the tacks, and could only work till the sun went down.
My plan is to hook up the gas tomorrow, and finish welding and grinding the panel down. I will try to weld as much as I can from inside the bay, to try and avoid the wind.
Re: 1961 Microbus
Posted: Sat Nov 09, 2013 9:18 pm
by sweeth20007
Nice work Mike! Thanks for posting.
Re: 1961 Microbus
Posted: Sun Nov 10, 2013 9:55 am
by heyed67
right on man looks like progress is being made..you know you have the dedication if u'r fighting the elements in the driveway!. It's all wourth it when you near the end of the project you'll forget about all the BS weather in NE ohio. 8-)
Re: 1961 Microbus
Posted: Sun Nov 10, 2013 5:12 pm
by tferr
Looking Great Mike! Hope it wasnt as windy there as it was here today
Re: 1961 Microbus
Posted: Sun Nov 10, 2013 5:17 pm
got a little over 3 hours in today. new total 156 hours
started by finishing up the welding, then slapped a layer of 'glass on the seam
let that dry, sanded, then threw on a skim of bondo
then sprayed a quick coat of rattle can to protect it for the winter
remember guys, its important to mask off any areas you do not want to get overspray on :o
that should keep the rust at bay until late spring when I can do a proper prep job and final paint (not rattle can)
Finished result
Re: 1961 Microbus
Posted: Sun Nov 10, 2013 6:14 pm
Mike Kever Kombi wrote:With that back in, it was time to tack up the panel. Obi Wan Kirk Nobi gave me some sagely advice about installing the Gerson corners. He said "if there is one thing I cannot stress enough its....." I forget what he said, so I decided to wing it.
Haha...I wing everything :lol:
Keep it up man.
Re: 1961 Microbus
Posted: Mon Nov 11, 2013 7:30 am
Wow, this looks really good Mike. Keep up the good work... I was hoping to see updates on this project.
We have matching corners now.
Re: 1961 Microbus
Posted: Mon Nov 11, 2013 12:17 pm
Except Kirk's skills are light years ahead of mine.
Re: 1961 Microbus
Posted: Wed Sep 03, 2014 7:14 pm
+2
158
Cut, fit, and zipped. Will tack/weld when front is at same point, to make sure everything lines up.
Re: 1961 Microbus
Posted: Wed Sep 03, 2014 10:45 pm
The thread is alive!!!!
