Have to get going on this thing or it will sit forever. Pulled the juggs off and got those little clips out to release the wrist pins which I pounded out with a deep socket. That released the pistons. I didn't lose any of those clips!
End play seemed bad at first, but checked it at Dale's and it was "ok". Still within the limit. I really don't want to split this case right now, so although it's getting near the wear limit, I don't drive it enough or drive it hard where I'm all that concerned.
Here's the case. For what it's worth, (probably nothing), the cam lobes & crank look good.
A lot of carbon buildup and just dirt on engine parts. Engine building is a dirty job! Note: I did remember to mark the cylinders and pistons!
When Kirk came by a couple weeks ago, he told me to "hone" the cylinders and get new rings. I didn't understand "honing"
Well, I had them soaking at Dale's, but Dale got them "honed" before I could get back there after work! So, while I have a good idea of what's involved, I still don't know the full procedure because I have not done it myself. Anyway, they came out nice.
Pistons came out of the tank pretty clean.
I forgot to take pictures, but we got the main seal replaced, cleaned the flywheel and put in a new clutch disc. The old one was still serviceable, but when the motor is out the motor is out! So a new one went in. Here's the old one.
Got everything back together this afternoon.
If Dale has time tomorrow he'll compress the rings. I don't know how to do that yet. Someday I hope to learn and get the tool you need. Hopefully I can start putting it together this weekend.
